15 years agopausing target processor: not responding
hi all, i hav build a system in sopc builder using nios ii cpu, jtag_uart, esps_flash_controller, ddr_high_performance_memory_controller, tse_mac, sgdma_rx, sgdma_tx, flash_tristate_bridge, ext_f...
15 years agothanks for your reply. . .
to cris, am using quartus ii 8.1v which i downloaded from the net and there it is mentioned that no licence required. before i used niosii_ethernet_standard design example there i managed to run hellow_word pgm on nios ii processor, but the problem is with the system which i have built. am not closing open core plus window, in my case am using an ip which will reset after an evaluation time of 4 hours so the time remaining is 4 hours. is this the reason which is causing that problem. . . thank you. . .
