15 years agopausing target processor: not responding
hi all, i hav build a system in sopc builder using nios ii cpu, jtag_uart, esps_flash_controller, ddr_high_performance_memory_controller, tse_mac, sgdma_rx, sgdma_tx, flash_tristate_bridge, ext_f...
15 years agoSearch the forum. This is a faq.
Common problems: - are you using unlicensed cores in OpenCore mode? Then you should not close the USB-Blaster message upon fpga configuration - check if your Quartus design meets all timings
