AKhaa
7 years agoPause the counter when a button is pressed, and resume the counter once the button is pressed again.
I tried to do some modification in binary counter example which comes with niosiiesd. But i can't get my required output. My irq value in qsys is 2 for button. Some one help me to sort out this issue. Thanks
#include "count_binary.h"
/* A "loop counter" variable. */
static alt_u8 count;
/* A variable to hold the value of the button pio edge capture register. */
volatile int edge_capture;
#ifdef BUTTON_PIO_BASE
#ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
static void handle_button_interrupts(void* context)
#else
static void handle_button_interrupts(void* context, alt_u32 id)
#endif
/* Cast context to edge_capture's type. It is important that this be
* declared volatile to avoid unwanted compiler optimization.
volatile int* edge_capture_ptr = (volatile int*) context;
/* Store the value in the Button's edge capture register in *context. */
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE);
/* Reset the Button's edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0);
* Read the PIO to delay ISR exit. This is done to prevent a spurious
* interrupt in systems with high processor -> pio latency and fast
* interrupts.
/* Initialize the button_pio. */
static void init_button_pio()
/* Recast the edge_capture pointer to match the alt_irq_register() function
* prototype. */
void* edge_capture_ptr = (void*) &edge_capture;
/* Enable all 4 button interrupts. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0);
/* Register the interrupt handler. */
alt_ic_isr_register(BUTTON_PIO_IRQ_INTERRUPT_CONTROLLER_ID, BUTTON_PIO_IRQ,
handle_button_interrupts, edge_capture_ptr, 0x0);
#else
alt_irq_register( BUTTON_PIO_IRQ, edge_capture_ptr,
handle_button_interrupts);
#endif
#endif /* BUTTON_PIO_BASE */
/* Seven Segment Display PIO Functions
* sevenseg_set_hex() -- implements a hex digit map.
#ifdef SEVEN_SEG_PIO_BASE
static void sevenseg_set_hex(int hex)
static alt_u8 segments[16] = {
0x40, 0x79, 0x24, 0x30, 0x19, 0x12, 0x02, 0x78, 0x00, 0x18, /* 0-9 */
0x88, 0x00, 0x46, 0x40, 0x06, 0x0E }; /* a-f */
unsigned int data = segments[hex & 15] | (segments[(hex >> 4) & 15] << 8);
IOWR_ALTERA_AVALON_PIO_DATA(SEVEN_SEG_PIO_BASE, data);
usleep(1000000);
#endif
static void lcd_init( FILE *lcd )
/* If the LCD Display exists, write a simple message on the first line. */
LCD_PRINTF(lcd, "%c%s Counting will be displayed below...", ESC,
ESC_TOP_LEFT);
static void initial_message()
printf("\n\n**************************\n");
printf("* Hello from Nios II! *\n");
printf("* Counting from 00 to ff *\n");
printf("**************************\n");
static void count_led()
#ifdef LED_PIO_BASE
LED_PIO_BASE,
count
#endif
static void count_sevenseg()
sevenseg_set_hex(count);
#endif
static void count_lcd( void* arg )
FILE* __attribute__ ((unused)) lcd; /* Attribute suppresses "unused variable" warning. */
lcd = (FILE*) arg;
LCD_PRINTF(lcd, "%c%s 0x%x\n", ESC, ESC_COL2_INDENT5, count);
/* count_all merely combines all three peripherals counting */
static void count_all( void* arg )
count_led();
count_sevenseg();
count_lcd( arg );
printf("%02x, ", count);
static void handle_button_press(alt_u8 type, FILE *lcd)
/* Button press actions while counting. */
if (type == 'c')
switch (edge_capture)
/* Button 1: Output counting to LED only. */
/* Button 2: Output counting to SEVEN SEG only. */
case 0x1:
count_sevenseg();
break;
/* Button 3: Output counting to D only. */
case 0x4:
count_lcd( lcd );
break;
/* Button 4: Output counting to LED, SEVEN_SEG, and D. */
case 0x8:
count_all( lcd );
break;
/* If value ends up being something different (shouldn't) do
same as 8. */
default:
count_all( lcd );
break;
/* If 'type' is anything else, assume we're "waiting"...*/
else
{ printf("* interrput *");
edge_capture = 0;
if (edge_capture = 2)
edge_capture = 0;
count_all(lcd);
else
usleep(5000000);
int main(void)
int i;
int __attribute__ ((unused)) wait_time; /* Attribute suppresses "var set but not used" warning. */
FILE * lcd;
count = 0;
/* Initialize the LCD, if there is one.
lcd = LCD_OPEN();
if(lcd != NULL) {lcd_init( lcd );}
/* Initialize the button pio. */
init_button_pio();
#endif
/* Initial message to output. */
initial_message();
/* Continue 0-ff counting loop. */
while( 1 )
usleep(100000);
if (edge_capture != 0)
/* Handle button presses while counting... */
handle_button_press('d', lcd);
/* If no button presses, try to output counting to all. */
else
count_all( lcd );
* If done counting, wait about 7 seconds...
* detect button presses while waiting.
if( count == 0xff )
edge_capture = 0; /* Reset to 0 during wait/pause period. */
wait_time = 0;
for (i = 0; i<70; ++i)
printf(".");
wait_time = i/10;
LCD_PRINTF(lcd, "%c%s %ds\n", ESC, ESC_COL2_INDENT5,
wait_time+1);
printf( "\nYou pushed: " );
usleep(100000); /* Sleep for 0.1s. */
/* Output the "loop start" messages before looping, again.
initial_message();
count++;
LCD_CLOSE(lcd);
return 0;
- Vicky1
Please, provide below details for replication,
- Quartus edition & version.
- Board/Kit used
- current observation as a output
Best Regards
Vikas Jathar
- Vicky1
Please refer the below link & try to understand available examples that may help to code your logic,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii52004.pdf
Best Regards
Vikas Jathar
