15 years agoParallel Flash memory access failed
Hello, I am designing a simple system with a 4CE40 and a Spansion flash memory (S29GL512 : 64MB in 16bits organisation). But when I make a "hello world" software, it fails at "checking" step. H...
14 years ago --- Quote Start --- Are you finished the project and working well with the flash? May you post the Qsys connections design!? --- Quote End --- Hello haulisson, Welcome to the forum. I attached two Qsys designs for the Nios II Embedded Evaluation Kit, Cyclone III Edition (NEEK). One is with sdram and flash memory, each having its owm address and data buses. The other is with ssram and flash memory, both sharing the same address and data buses. The generic tristate controller component for the external Flash memory needs to be configured for the specific Flash memory device in your system. Likewise, the pin sharer component used in the latter example needs to be configured for your design.
