14 years agoOptimize a single file in a project
What is the easiest way with NIOS II EDS 10.1sp1 to setup the auto-generated Makefile to optimize a single file? By default the project has optimization turned off, but I'd like to enable it on a si...
14 years agoI have never created a library in the GUI but if that doesn't work you can always do that from the command line.
