14 years agoOptimize a single file in a project
What is the easiest way with NIOS II EDS 10.1sp1 to setup the auto-generated Makefile to optimize a single file? By default the project has optimization turned off, but I'd like to enable it on a si...
14 years agoI'm trying to do that right now, but the SBT doesn't give me the option to set the optimization flags with the library. Either I'm doing something wrong, or the "New Library" path does not following the documentation at all.
