20 years agoOpencores I2C writing: Only 2 scl positive edges
I want to integrate Opencores I2C master IP core in one NIOS II projects. I have added it in the NIOS II system and compiled the project in Quartus II successfully.
I have enabled the pull-up features for the scl and sda pin in the quartus assignment editor. The I2C master may work abnormally when my program tries to write a byte to the I2C slave. There are only two positive edges of scl for the i2c slave device address phase. There should be 9 positive edges of scl. QUartus's version is 5.1 SP2. NIOS IDE's version is 5.1 SP1. I use Stratix 1S10 dev. kit to test the opencores I2C master core. The codes is writing according the examples. void i2c_write(unsigned char address, unsigned char data) { i2c_wait_tip(); // write address IOWR_I2C_TXR(address<<1); IOWR_I2C_CR(I2C_CR_STA | I2C_CR_WR); i2c_wait_tip(); // write data IOWR_I2C_TXR(data); IOWR_I2C_CR(I2C_CR_WR | I2C_CR_STO); i2c_wait_tip(); } Is the opencores I2C work well? How can I fix it? How can I attach pictures in this forum? I can post the pictures.1 Reply
i think internal fpga pullups are too weak,
you should use external resistors <10k (e.g. 1k)
