13 years agoOpenCores I2C No Output Signal
Hi guys, First off, I just started using FPGAs about a month ago, and am only just beginning to use Nios II, so suffice to say I am very new to this. I'm working with a DE0 Nano on project...
13 years agoHi Daixiwen,
Thanks for the tip. I've been sending multiple signals after the I2C_INIT command, but the clock still fails to toggle (I sampled it using a Logic Analyser while it was supposed to be sending the signals) Neither SCL not SDA change. I really don't know what's going wrong and where. I suspect it might be resets, so I'll try adjusting those. If you have any more suggestions, do let me know! Thanks!
