13 years agoOpenCores I2C No Output Signal
Hi guys, First off, I just started using FPGAs about a month ago, and am only just beginning to use Nios II, so suffice to say I am very new to this. I'm working with a DE0 Nano on project...
13 years agoVCC is the expected state of both lines when you aren't doing anything on the I2C bus. Even the clock will only toggle when you are actually using the bus. Try to read or write something and see if the clock line toggles then.
