14 years agoON-Chip Memory is too small for the source code
Hi, I´m a newbie in Altera and now I got a problem. I want lo load my source code to control my IP Core. I have a cyclon III DEV Board which has maximum 3888kbits of on chip memory but my code ...
14 years agoOption 1
If you want to move a whole memory section to ddr2 or to any another memory, select it in the BSP properties. e.g. : stack in onchip memory, code in ddr2, data in ddr2, ... Option 2 If you want to move a single function to a specific memory, add __attribute__ ((section (".my_memory"))) after the function declaration, where 'my_memory' is the name you assigned to your memory in sopc builder or Qsys. e.g. int function_in_ddr2(int param) __attribute__ ((section (".ddr2_ext_mem"))); Option 3 Use a custom linker scripts and map whatever you want wherever you need.
