9 years agoOn-Chip Memory instruction corruption
We have a design which uses a NIOS CPU whose instruction code is stored in On-Chip Memory. Most of the time everything works however there are times when the code is changed slightly and either the f...
9 years agoMy 2 cents; If you suspect a timing problem, try slowing down the clock and see if the problem persists.
