9 years agoOn-Chip Memory instruction corruption
We have a design which uses a NIOS CPU whose instruction code is stored in On-Chip Memory. Most of the time everything works however there are times when the code is changed slightly and either the f...
9 years agoI have worked on the timing and got the violations down a lot - I have posted the report. The remaining are violations don't appear to be significant (at least to the area of the design that I am working on)
I check the design and it is still showing this bug ??????
