9 years agoOn-Chip Memory instruction corruption
We have a design which uses a NIOS CPU whose instruction code is stored in On-Chip Memory. Most of the time everything works however there are times when the code is changed slightly and either the f...
9 years agoI checked non of my IO are constrained - but is this really going to matter ? I am now trying a compile with my QSPI Flash "Active Serial Clock Source" reduced down from 100Mhz to 12.5MHz !
