9 years agoOn-Chip Memory instruction corruption
We have a design which uses a NIOS CPU whose instruction code is stored in On-Chip Memory. Most of the time everything works however there are times when the code is changed slightly and either the f...
9 years agoHow well constrained is your project? How fast is your Nios running? Does it all meet timing? By adding the code you're adding are you exercising part of the logic that has a timing issue but not doing so without the extra code?
Cheers, Alex
