15 years agoObject mode buffer VHDL
How do you use the buffer in VHDL, I get errors saying that I need to change object mode to buffer. Here is a piece of the code where it is telling me to use it.
This is not the whole code: Thanks Heath LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY mux4to7segdisplay IS PORT ( NUM1 :IN std_logic_vector (3 DOWNTO 0); NUM2 :IN std_logic_vector (3 DOWNTO 0); S :IN BIT; --bcd :IN std_logic_vector (3 DOWNTO 0); A :OUT BIT; B :OUT BIT; C :OUT BIT; D :OUT BIT; E :OUT BIT; F :OUT BIT; G :OUT BIT); END mux4to7segdisplay; ARCHITECTURE display OF mux4to7segdisplay IS BEGIN PROCESS (S,NUM1,NUM2,A,B,C,D,E,F,G) BEGIN IF (S='0')Then IF (NUM1="0000") THEN A<='1'; B<='1'; C<='1'; D<='1'; E<='1'; F<='1'; G<='0'; ELSIF(NUM1="0001")THEN A<='0'; B<='1'; C<='1'; D<='0'; E<='0'; F<='0'; G<='0'; ELSIF(NUM1="0010")THEN1 Reply
You should not put A~G in sensitivity list. Because you cannot read outputs.
buffer is hardly needed. It means your port is an output "driven by your module" but can be read if required.
