15 years agonon-cacheable instruction memory
Hi at all, I'm new in this forum. I create a Nios II system containing a Nios II/f core, with 2k data cache and 2k instruction cache, and 128k of on chip-memory. I want to run on this system an ...
15 years agoThank you for the answer, but now I have another problem. When I map the .text section into tightly coupled memory and I debug an assembler code on hardware the Nios II IDE gives this error:
--------------------------------------------------------------------------------- Downloading 02100020 ( 0%) Downloading 04000000 ( 1%) Downloading 06000000 (21%) Downloaded 39KB in 0.6s (65.0KB/s) Verifying 02100020 ( 0%) Verifying 04000000 ( 1%) Verifying 06000000 (21%) Verify failed between address 0x6000000 and 0x6007923 Leaving target processor paused -------------------------------------------------------------------------------- 0x6000000 is the starting address of the tightly coupled memory. What does it mean??? How can I solve it??? Thank you. Rolfo Daniele.
