15 years agonon-cacheable instruction memory
Hi at all, I'm new in this forum. I create a Nios II system containing a Nios II/f core, with 2k data cache and 2k instruction cache, and 128k of on chip-memory. I want to run on this system an ...
15 years agoYou can't, instructions read from an Avalon slave have to read into the instruction cache first.
What you can do is use a tightly coupled memory block for the instructions. You'll probably need to make the memory blocks second port a slave to the avalon bus and give the cpu data access to it. If you want to use the jtag debugger, you'll still need the instruction master and a minimal instruction cache.
