15 years agoNo data transmission between board and pc
Hi all,
I'm working on a DE2 Board and i'd like to send data from the board to my pc via ethernet. To reach my target i've built a very easy system on SOPC builder with: - nios2\s - onchip_mem (20k) - jtag uart (to display some messages) - sysid - dm9000a (taken from DE2_NET demo) Then i've written some simple code to transmit data from the board to my pc. Apparently there aren't errors, but when i run my code, it stops @: while(!(ior(NSR)&0x0C)) in the transmitPacket function of the "dm9000a.c" file i've tryed with a cross cable and also with a switch, but it won't work in bot cases... in my main() code i've called the init function, and then,inside while (1) , the transmitpacket function with the right parameters... The leds at the bottom of my board's ethernet port, never light up... is an hw problem? or i forget something that i can't see? Anyone can help?1 Reply
Did you solve this?
