8 years agoNo console message in uCLinux
Dear all, We are preparing one design for Arria 10 GX Development kit. That design is having following components: Nios II (Gen2) Processor with MMU enabled DDR4 memory. On-chip mem...
8 years agoHello,
First of all thanks to those who read my post and tried to see whether they can help or not. At last, we were able to get past that issue. I am sharing how we solved it here. Hope this could be helpful to someone in future.- We ensured that all peripherals (including memories) connected to Nios II's instruction master and data master are within address range: 0x0 to 0x1FFFF_FFFF. (Not very sure why we need to ensure this.)
- We made following manual changes in DTS file generated from .sopcinfo
- DDR4 memory is not located under memory section. Hence we manually edited it under memory section and comment it out from other section.
- Under CPU section, 'altr' needs to be replaced with 'ALTR'. It seems that to use Nios II gen2 processor with Linux kernel version 3.4, this change is required. (I read this somewhere on Rocketboards.org)
