Julien
7 years agoNIOSII/e peripheral IO read access performance?
Hi, I am using a design that includes a NIOSII/e (the "e" is important here), that accesses a UART IP as an Avalon slave. Works fine, but I timed the duration of each individual word read access, an...
Julien
7 years agoHi Anand,
I have tested reading from the onchip memory instead of the UART's FIFO, unfortunately it gives me the exact same result : reading one byte takes around 5µs
Can you please confirm the sample capture you provided was done with a NIOSII/e, not a NIOSII/f ?
I will try to use signal tap to capture the av_ld_waiting_data in my case.
Julien
