Julien
7 years agoNIOSII/e peripheral IO read access performance?
Hi, I am using a design that includes a NIOSII/e (the "e" is important here), that accesses a UART IP as an Avalon slave. Works fine, but I timed the duration of each individual word read access, an...
AnandRaj_S_Intel
7 years agoHi Julien,
- Instead of using UART IP(Because IP is like UART or SPI are slow) use on chip ram to see the difference in timing also use Alavon Pipeline IP.
- Use signal-tap and monitor the av_ld_waiting_data or av_ld_waiting_data_nxt signal. you can find that time given in document matches the processor time excluding the time on waiting for response or request.
Attached image of signal-tap image hope it helps.
Anand
