Julien
7 years agoNIOSII/e peripheral IO read access performance?
Hi, I am using a design that includes a NIOSII/e (the "e" is important here), that accesses a UART IP as an Avalon slave. Works fine, but I timed the duration of each individual word read access, an...
AnandRaj_S_Intel
7 years agoHi,
Yes, you are correct.but Duration of Avalon-MM read transfer is variable right,
Avalon-MM transfers transmit up to 1024 bits at a time, and take one or more clock cycles to complete(The shortest duration of an Avalon-MM transfer is one cycle).
One instruction per 6 clock cycles so 6 cycle is the max, No processor executes a full command in one single clock cycle.
However try optimizing the design that may help to reduce the timing.
Anand
