14 years agoNiosII SPI read problem
Hello everyone! I am using the SPI core in niosII to connect my fpga to peripheral and I am experiencing problems only when I try to read data from the peripheral. I first write certain data to...
14 years agoIf You're using SPI as master, then MISO pin must be INPUT (Master In Slave Out). Anyway, the clocking rate of the SCK signal is determined in core parameters and are not changeable afaik, so I doubt it's a speed issue.
