16 years agoNiosII is slow? Or something I am doing wrong.
Hi all, I am playing with Cyclone II chip. It is custom board and there is ATMEGA16 running at 12MHz and FPGA with master clock 50MHz. FPGA is translating data from internal dualport memory ...
16 years agoI got curious so I compiled the code you posted for both Nios and for AVR and compared the compiled code.
One thing I noticed that may account for the lack of expected performance is that Nios does not use any hardware acceleration for FP comparisons. For example, your inner loop does a comparison with the limit variable. On Nios this calls a subroutines totaling about 183 opcodes. (Less than this will actually execute due to the different possible branches taken, but this is a quick number for comparison purposes.) I also looked at the AVR code for the same comparison. If you link in the hand optimized assembler libm.a library, there are a total of about 40 opcodes. This is a lot more efficient than the Nios case. If you don't use libm.a but instead let GCC use it's own library (as is done with Nios), then the total opcodes is a little over 400. Are you using libm.a with your AVR tests? If you are just trying to compare performance of the architectures, a more fair test would be to not use libm.a with AVR. I have a feeling the lack of performance is mostly due to the poorly optimized FP operations for which Nios does not have hardware acceleration. I wonder if there is an easy way to accelerate the FP comparisons with Nios? It would probably make a big difference if you did this. Another similar inefficiency I noticed is the conversion of x, y and limit to floating point values. I suspect even changing the compare to limit to a compare to a constant value of 4 will make a small noticeable difference. The compiler is not optimizing the fact that limit is actually a constant.
