16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoSo, I did a bunch of testing and experimenting and I need help
to clarify things that may put this thing to rest. Firstly, I have only NIOS, DDR, On-chip mem, and JTAG in the system and I have reduced the clocks for all possible to the 50MHz sysclk. With this, all critical warnings have been removed as previously stated. The result with 4x address incrementing is like this: 1: wrote 00000001, test_addr 00000000, read_val 00000004, device 0 2: wrote 00000002, test_addr 00000004, read_val 00000004, device 0 3: wrote 00000004, test_addr 00000008, read_val 00000008, device 0 4: wrote 00000008, test_addr 0000000c, read_val 00000008, device 0 5: wrote 00000010, test_addr 00000010, read_val 00000040, device 0 6: wrote 00000020, test_addr 00000014, read_val 00000040, device 0 7: wrote 00000040, test_addr 00000018, read_val 00000080, device 0 8: wrote 00000080, test_addr 0000001c, read_val 00000080, device 0 ... etc, etc and with 8x address incrementing is like this: 1: wrote 00000001, test_addr 00000000, read_val 00000001, device 0 2: wrote 00000002, test_addr 00000008, read_val 00000002, device 0 3: wrote 00000004, test_addr 00000010, read_val 00000004, device 0 4: wrote 00000008, test_addr 00000018, read_val 00000008, device 0 5: wrote 00000010, test_addr 00000020, read_val 00000010, device 0 6: wrote 00000020, test_addr 00000028, read_val 00000020, device 0 7: wrote 00000040, test_addr 00000030, read_val 00000040, device 0 8: wrote 00000080, test_addr 00000038, read_val 00000080, device 0 etc, etc, ... 8x incrementing looks to provide correct results but that means that since we only get 4 bytes per read from NIOS that we are missing the other 4 bytes assuming the addresses provided to the _32DIRECT RD/WR macros are byte addresses. I confirmed that with 8x addr incrementing that I cannot write past the span of 0x10000000(256MB which is size of device). I used SignalTap to look at the *local* signals and addresses and this seems the root of the problem. When using 4x incrementing then the local_address increases as 0,0,1,1,2,2,3,3, etc. for every local_read_req pulse. When using 8x incrementing then the local_address increases as 0,1,2,3, etc. So, here, 8x looks correct but then since I can only access up to the span 0x10000000 (256MB if byte addr) before NIOS returns 0xFFFFFFFF as data and the devices are 256MB then half the addresses are not available apparently. Note for the reads the data for one of the 8x reads on this local_rdata bus (64 bits wide) is: 0x00000002_00000002 Note for the reads the data for one of the 4x reads on this local_rdata bus (64 bits wide) is: 0x00000004_00000004 How do I access ____ALL____ 256MB of this device. The emi_ddr_ug.pdf by Altera shows local_address on page 121 which talks about "LSB of column address on memory side is ignored" which may be of some relevance. Does this mean we ____WILL____ only see half of our memory??? Thank-you.
