16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoYes you should close timing before expecting your software to work. Same goes for using Signaltap II. I also would prototype at a much lower speed to start, make sure the memory accesses are functional, and then crank the clock up.
If you simulate this system you won't need to meeting timing since you'll just be verifying it at a functional timing level. After the functionality looks right in simulation then you could move on closing timing. clk to clk transfers are going to be the majority of your design (register to register transfers will normally be on the same domain). If the TNS (total negative slack) is close to 0 then you could probably just do some Quartus II setting tweaks to meet timing. If the TNS is high then you might need architectural changes to achieve 200MHz.
