11 years agoNIOS/Eclipse can't find target
Hello all. I'm a little frustrated, as this was working yesterday; today the NIOS II Software Build Tools for Eclipse stopped working. When I go to run (run as -> NIOS II Hardware) an appl...
11 years agoYou can also try Run-> Run Configurations. Click on Nios II Hardware and select new. In the Project Tab, select the project name and elf file. Go to target connections, select 'ignore mismatch system id' and 'ignore mismatch system timestamp' and click on refresh connections. Finally click Apply and Run.
I hope this helps. Good Luck!
