8 years agoNios2/e Remote Upgrade in MAX10
Hi, I am trying to implement a remote FPGA upgrade configuration using a MAX10 FPGA with NiosII/e. Nios is running from UFM of max10 (Not enough OCRAM left for nios). and small ocram for ISRs. ...
8 years ago --- Quote Start --- That's great. Unfortunately I do not have the knowledge to do that. Could you show me how you directed the linker to place only these certain sections of code in OCRAM (and which sections exactly). Are you using Much appreciated. David --- Quote End --- Sure. Here are the steps I took. 1. Edit BSP with an ocram private(you can use any name) sector. https://www.alteraforum.com/forum/attachment.php?attachmentid=14599 2. You need to edit the linker script of NIOS. For example:
Rest of the script...
.private : AT ( LOADADDR (.text) + SIZEOF (.text) )
PROVIDE (_alt_partition_private_start = ABSOLUTE(.));
*(.private .private.*)
. = ALIGN(4);
PROVIDE (_alt_partition_private_end = ABSOLUTE(.));
} > ocram_private
PROVIDE (_alt_partition_private_load_addr = LOADADDR(.private));
.rodata : AT ( LOADADDR (.private) + SIZEOF (.private) )
3. In C code, instruct linker to put function on private section, e.g.: __attribute__ ((section(".private"))) extern void write_page( ) 4. Edit bootloader(alt_load.c) to load that section memory, already a function available, just call: ALT_LOAD_SECTION_BY_NAME(private); Good Luck
