15 years agonios2-mmu linux stuck on #Switching to clocksource timer#?
hello, With socrates (http://www.alteraforum.com/forum/member.php?u=7474)'s tips, I soved the memory problem, but it still stuck, see the result:
Linux version 3.1.0-rc4-01162-g45c9dd8-dirty ...
15 years ago --- Quote Start --- Did You set the system timer to have IRQ 0? It's a requirement. --- Quote End --- Yes, I try to set it, but it stuck more ealy,see the result:
cc version 4.1.2)# 51 Sun Oct 9 22:31:39 CST 2011
bootconsole enabled
early_console initialized at 0xe2004000
On node 0 totalpages: 2048
free_area_init_node: node 0, pgdat d0334390, node_mem_map d034e8a0
DMA zone: 16 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 2032 pages, LIFO batch:0
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: 0
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032
Kernel command line: bootargs="debug console=ttyAL0,115200"
PID hash table entries: 32 (order: -5, 128 bytes)
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 4696k/3377k RAM (1043k kernel code, 2333k data)
NR_IRQS:32
Calibrating delay loop...
why?:cry: If I comment out the calibrate_delay() in the main.c of kernel, I still stuck on the# Switching to clocksource timer#,see the result:
NR_IRQS:32
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 512
bio: create slab <bio-0> at 0
regards
