15 years agoNIOS2 HW & DIV Instructions + FPU
Hello i am in charge of designing a system that does a lot of complex sin/cos/* instructions and i need them to be fast. I am using NIOS2-F at 100mhz in a Cyclone IV. I've enabled HW and DIV ...
15 years agoDepending on what you are doing you might be able to reduce the amount of maths required!
If you only need limited precision use a lookup table and linear interpolation (and maybe a single newton-raphson step). If you are generating values in sequence (eg tone generation) then use the equality: sin(a+b) = 2sin(a)cos(b) - sin(a-b) Use fixed-point maths (in integers) rather than floating point.
