10 years agonios2-flash-override
Hello, Could anyone please confirm, that nios2-flash-override.txt method does not work in Quartius 15.1.2 neither in the gui nor in the command line untill indicated directly with the --override o...
9 years agoThanks Smersh...
I'm not really in a mood of patching the flash programmer, even though the temptation is high... I thus first contacted Support who suggested to use .jic files... after one night working on that I gave up! Then I tried with command line as you suggested, and after some slight adjustments it works. Thanls for your suggestion jylo
