10 years agonios2-flash-override
Hello, Could anyone please confirm, that nios2-flash-override.txt method does not work in Quartius 15.1.2 neither in the gui nor in the command line untill indicated directly with the --override o...
9 years ago --- Quote Start --- I concur! I do have the same problem when migrating a project that was developed under Quartus II 13 to Quartuse II 16.1! Any solution? Any feedback from Altera? Thanks Jylo --- Quote End --- Command line should work for you. If you want to run the flash programmer from the GUI, you can probably patch the flash programmer executable in the hex editor, substituting the EPCS chip name with the one you need. This method helped me with the DE0-Nano board, but won't work for every chip. NJ
