14 years agonios2-download problem uClinux
I'm trying to get uClinux working on my development board. I walked all the steps i founded on alterawiki At the moment that i want to download the image to the board by the following actions: cd nios2-linux/uClinux-dist nios2-configure-sof /home/bart/Nios2.sof nios2-download -g /home/bart/nios2-linux/uClinux-dist/images/linux.initramfs.gz I get the following error on the last step: /home/bart/altera/11.1/nios2eds/bin/nios2-download: line 596: nios2-elf-objcopy: command not found /home/bart/altera/11.1/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: No such file or directory rm: cannot remove `/home/bart/nios2-linux/uClinux-dist/images/linux.initramfs.gz.srec': No such file or directory Can anyone help me with my problem?5 Replies
Please, can anyone help me with this problem?
Did you try to launch sdk_shell in nios2eds folder ?
cd ~/altera/11.1/nios2eds ./nios2_command_shell.sh ./sdk_shell exit - Altera_Forum
Thanks for replaying, it was helpful...
It solved my problem but now if have another problem: nios2-gdb-server-wrapped: nios2debug.cpp:578: virtual ADI_ERRO NIOSDEBUG::leave_debug_mode(): Assertion `m_STATE_DEBUG' failed. /home/bart/altera/11.1/nios2eds/bin/nios2-download: line 609: 939 Aborted nios2-gdb-server --go --tcpport none --write-pid /home/bart/nios2-linux/uClinux-dist/images/nios2-download.pid /home/bart/nios2-linux/uClinux-dist/images/linux.initramfs.gz.srec I think there is something wrong in my quartus project, anyone a idea what it cute be - Altera_Forum
So nios2-configure myfgpa.sof command is working i suppose ?
But download Kernel image failed. Did you try to use nios2-download -g myapp.elf command with a simple program like "hello world" on your fpga sof ? - Altera_Forum
I tried it, and it failed.. So i think that my nios2 is corrupted! Something wrong with the connection to the SDRAM i suppose
There is still somethings to do :) thanks for you help!!
