14 years agoNIOS2 Command Shell
Hi all, does somebody know if exist some instalation package with only NIOS2 Command shell for running nios2-terminal, nios2-download, elf2flash, sof2flash and nios2-programmer ? I need...
14 years agoI think at a minimum you would need to install the Nios II EDS and standalone JTAG programmer. I'm not sure if the Nios II EDS installer will let you install it without Quartus II installed though. You need to JTAG programmer so that nios2-download will work. I would give it a shot and see if it works, post your results here with what you find out.
