9 years agonios2-bsp-create-settings failed error
Hi everyone, I am getting this error when I am trying
new-> Nios II Application and BSP from Template Compilation is successful in Quartus. But I can not create a Project in eclipse. I am using the version 13.0sp1. Thanks for the answers. INFO: Finished initializing SOPC project local software IP. Total time taken = 4 seconds INFO: Searching for BSP components with category: driver_element INFO: Searching for BSP components with category: software_package_element INFO: Loading drivers from ensemble report. INFO: Finished loading drivers from ensemble report. SEVERE: Setting does not exist for BSP: "hal.stdın". WARNING: Tcl script "bsp-set-defaults.tcl " error: Setting does not exist for BSP: "hal.stdın". SEVERE: Setting does not exist for BSP: "hal.max_file_descriptors". SEVERE: Setting does not exist for BSP: "hal.max_file_descriptors". SEVERE: nios2-bsp-create-settings failed. nios2-bsp: nios2-bsp-create-settings failed nios2-bsp hal . C:/altera/13.0sp1/proj_Helloworld/proj_qsys.sopcinfo --set hal.max_file_descriptors 4 --set hal.enable_small_c_library true --set hal.sys_clk_timer none --set hal.timestamp_timer none --set hal.enable_exit false --set hal.enable_c_plus_plus false --set hal.enable_lightweight_device_driver_api true --set hal.enable_clean_exit false --set hal.enable_sim_optimize false --set hal.enable_reduced_device_drivers true --set hal.make.bsp_cflags_optimization '-Os' --cpu-name nios2_qsys_0 failedNo RepliesBe the first to reply
