20 years agoNIOS Uart : change baud rate
I am having trouble to change the baud rate of a NIOS avalon uart. Note that I am not running against any OS, just the "standard" native NIOS environment. I tried : alt_avalon_uart_ioc...
9 years ago --- Quote Start --- For being able of modifying the UART baudrate, check theese: - In SOPCBuilder open the editor dialog for the UART component in your system (double click on it), there is a parametter for including an UART bauderate register; - Make sure that you're not using the reduced footprint driver's HAL mode in your system library; - Include this define ALTERA_AVALON_UART_USE_IOCTL in the compiler preprocessor configuration settings for your system library and recompile it; - Add the includes# include <sys/ioctl.h> and# include <sys/termios.h> to your source file; Now you can use code like this for changing the uart speed: struct termios termios; int res = ioctl( uartfd, TIOCMGET, &termios ); termios.c_ispeed = your_new_bauderate; termios.c_ospeed = your_new_bauderate; res = ioctl( uartfd, TIOCMSET, &termios ); The above code can be used provided that you opened the uart using code like: int uartfd; uartfd = open( your_uart_device_name, O_RDWR | O_NONBLOCK | O_NOCTTY ); if (uartfd == -1) { printf( "FATAL ERROR with uart \"%s\"\r\n", uart_name ); return 1; } The options are ORed according to my needs, which could be a little bit different from yours. --- Quote End --- Hi, Regarding the sentence : Include this define ALTERA_AVALON_UART_USE_IOCTL in the compiler preprocessor configuration settings for your system library and recompile it; Can you please explain how its done? Thanks
