15 years agoNIOS SBT IDE Debugger Problems
I've been all over the forums and have yet to see an answer to this problem. I'm trying to debug some simple code using the debugger in the NIOS IDE. It basically reads/writes to on chip memor...
Jens
8 years agoI had the same problem. In my case the solution was to switch the debug level (properties->Nios2 application properties) from Off to On.
Jens
