15 years agoNIOS SBT IDE Debugger Problems
I've been all over the forums and have yet to see an answer to this problem. I'm trying to debug some simple code using the debugger in the NIOS IDE. It basically reads/writes to on chip memor...
15 years agoThis is very strange.
Did you perform the same LED test like above? Namely, are you sure your cpu is running and it stops at the breakpoint? After the breakpoint, can you resume or restart execution? Does your system have a watchdog timer or anything similar which could possibly reset the cpu when execution is suspended?
