15 years agoNIOS SBT for Eclipse HELP!!!!!!!
I cannot figure out how to get the SBT to open in eclipse and there is ZERO documentation about this online. All documentation seems to start with "open up the SBT for eclipse" and assumes that how t...
15 years agoAccording to IT I'm not behind a NAT. They did suggest that the software firewall that they have installed on each machine could be blocking the ports the installer needs, so you are probably right with the suggestion to turn off the firewall. Unfortunately, I don't have access to those settings.
The .iso install works fine and I have the NIOS SBT up and running. Thanks for the help!
