11 years agoNios problem with interfacing custom component
Hi, I am a newbie to Altera/Nios and have followed some tutorial to build a Nios2 system. Now I am trying to build a custom component with interface to the Nios2, but I am having some troubl...
11 years agoI would try to use the write signal instead of byteenable to qualify the writedata into the light_avalon module.
module light_avalon(clock, resetn, D, write, Q); input clock, resetn; input write; input [15:0] D; output reg [7:0] Q; always @(posedge clock) begin if (write) Q[7:0] <= D[7:0]; end endmodule The reason is that the Avalon interface into the light_avalon_interface can be receiving writedata, which is not intended for the light_avalon. By using the write signal, you will guarantee that the writedata is valid for your module. Hope this helps.
