SBure
8 years agoNios not starting if encryption feature enabled in Convert Programming File tool
I'm using Q13.1 and run Nios from EPCQ (EPCS/EPCQx1 Serial Flash Controller installed in Qsys). Nios binary copied from EPCQ to DDR after power up. I generate jic file using Convert Programming File ...
SBure
8 years agoHi, thanks for answer. I'm using hex file, which is generated like this:
#Create a flash image of your FPGA configuration file
sof2flash --input=hw.sof --output=hw.flash --epcq --verbose
#Note: We are using --epcq instead of --epcs here for EPCQ devices
#Create a flash image of your NIOS II .elf file
elf2flash --input=sw.elf --output=sw.flash --epcs --after=hw.flash –verbose
#Create the .hex image of your Nios II software
nios2-elf-objcopy --input-target srec --output-target ihexsw.flash sw.hex
