SBure
8 years agoNios not starting if encryption feature enabled in Convert Programming File tool
I'm using Q13.1 and run Nios from EPCQ (EPCS/EPCQx1 Serial Flash Controller installed in Qsys). Nios binary copied from EPCQ to DDR after power up. I generate jic file using Convert Programming File ...
Ahmed_H_Intel1
8 years agoAre you using the hex file as on-chip memory initialization file or separated file ? if the first option then I suggest to make it separated from the .sof
