16 years agoNios MPU. Problems after disabling Memory Protection Unit
Hello, I took the MPU usage example from the Nios Wiki as the starting point for using the MPU. I adapted it to my hardware (DE1 board), using the 512K off chip SRAM and a 16K onchip ram in pla...
16 years agoQuite possible the memory cycle you are doing is accessing some other part of the system - due to address aliasing - and that is causing the reset.
The SOPC builder doesn't seem to tell you the actual address decode rules it has put in place.
