ZKhan1
7 years agoNios-ll Interval Timer is not enabled
Hi there , I have been trying to run Nios-ll interval timer using the code given in Embedded IP core document the code gets stuck at ""No timestamp device available\n". I did included Interval Time...
ZKhan1
7 years agohmmm, i gets me thinking if sys_clk is left NONE will it effect other peripherals ???? i will test other peripherals and give you feed back .
