ZKhan1
7 years agoNios-ll Interval Timer is not enabled
Hi there , I have been trying to run Nios-ll interval timer using the code given in Embedded IP core document the code gets stuck at ""No timestamp device available\n". I did included Interval Time...
ZKhan1
7 years agoAccording to your solution , you are suggesting that i assign "NONE" for sys_clk_timer see screen shot attached .
I have also attached the previous setting pic .
