ZKhan1
7 years agoNios-ll Interval Timer is not enabled
Hi there , I have been trying to run Nios-ll interval timer using the code given in Embedded IP core document the code gets stuck at ""No timestamp device available\n". I did included Interval Time...
ZKhan1
7 years agoHi dsmirnov ,
your answer has confused me even more ,..... i have read various posts and the instructions in Embedded Ip core doc , all suggest that i have to specify in BSP editor that sys clk and timer stamp clk should be assigned to interval timer ???
Tell me step by step what i have to do to make it work , if i have to add another timer then which clk will derive it and how to set the old timer .
Thanks ,
