20 years agoNIOS little endian or big endian?
Hi, I have a C application, which was written for an x86 processor (i.e. using little endian) and tried running the given test cases for the application but they failed. I know that the NIOS II...
20 years agoAlso be carefull about the alignment of arrays and elements of structures.
PC-compilers will normally put arrays on at least 4 byte boundaries, where for nios for example an array of bytes can start for example at 2 byte boundaries. You can use the align pragma to change this behaviour. (for members of structures, use packed and align toghether)
