9 years agoNIOS Interval Timer Problem
Hi folks,
I am sure this will be a quick one for any of you seasoned pros out there: I have just added the interval timer to my qsys systm and rebuilt the BSP, but now when I run my program it jumps straight to the ISR for the timer as it is defaulting to being the system tick. I do not want this,I just need a timer that freely runs that I can query/stop/start and reset at my discretion. Is it possible to disable the default as a sys tick? I could define my own ISR that will override the default, but that means I have to allow at least one ISR branch before I can disable it. The timer is running at 10clk increments, with a 100Mhz clock input as I need quite a high resolution. Can anyone advise please? thank you. deBoogle2 Replies
In the BSP editor, you ought to be able to set hal.sys_clk_timer to "none". Or if you're having trouble doing that, take the easy way out and add another timer for your sys_clk_timer and tell your BSP to use that timer.
--- Quote Start --- In the BSP editor, you ought to be able to set hal.sys_clk_timer to "none". Or if you're having trouble doing that, take the easy way out and add another timer for your sys_clk_timer and tell your BSP to use that timer. --- Quote End --- Perfect. All sorted now thank you.
