10 years agoNios Interfacing with W5300
Hello, I want to perform a connection between Nios and Ethernet Module Wiznet W5300. Although connecting w5300 to pio would be easier for me I want to connect it directly to Avalon bus. Avalon ...
10 years ago --- Quote Start --- You are right. I think tri-state controller is better approach. In that case do I need also to use a tri-state conduit bridge along with the controller or not? --- Quote End --- If the device you are interfacing with has bi-directional signals, then yes. Otherwise, no. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_avalon_tc.pdf
