10 years agoNios Interfacing with W5300
Hello, I want to perform a connection between Nios and Ethernet Module Wiznet W5300. Although connecting w5300 to pio would be easier for me I want to connect it directly to Avalon bus. Avalon ...
10 years agoIf you haven't figured it out already, I think you probably want to look into using the Tri-State Conduit.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_avalon_tc.pdf Your W5300 device doesn't look that different from a flash or SRAM as is commonly used with the Tri-State Conduit component.
